- Jan 31, 2016
- 11,471
LOL , 18 years of staging just like on tv .Yes I have, but I don't recall stuff jumping out spontaneously!
for me it's the closed cell foam pads. One in the basement, one in the garage, and one in the shed. I am having problems playing volleyball, the diving is causing problems, I can't get up after beating my knees (w/gel pads) against the floor.Got me one of these here Gardener’s Kneeler & Seat thingamabobs off Amazon three years ago to save my knees and help getting back up when there wasn’t anything close by to lean on (then lost 90 lbs. and have only used it occasionally):
Yes, I used them, too (still do to cushion my knees). The kneeler has a closed cell pad built in, but the biggest help was the supports on each side: very easy to push myself up.for me it's the closed cell foam pads. One in the basement, one in the garage, and one in the shed. I am having problems playing volleyball, the diving is causing problems, I can't get up after beating my knees (w/gel pads) against the floor.
Would be great to be able to use one, but this is at the kick plate level on the floor.Ooh! Adjustable height collapsing stools! Cushy to be able to pick the "just right" height, and they are also handy when you need to block something that is in the 3" to "stool" height range...
Sent from my SM-G715A using Tapatalk
have you ever cleaned it with vinegar. It could be crud from hard water.Speaking of dishwashers, ours has started acting up. It doesn't always fill. When it doesn't I have to turn it off and start again. Sometimes it takes 2 or 3 tries, other times 10. I've convinced myself it's either the fill valve or the control board. The valve is about $20, but I have to pull the unit out of it's cubby. The circuit board is $120 and is in the door. My wife is getting impatient waiting for me to decide which way to jump.
