- Sep 2, 2013
- 5,099
I've been having to raise my pump every 5-6 years, as I have iron bacteria which turns to a rusty slime, which is harmless to ingest, and is for the most part removed by filters and water softener for the house, but precipitates out in the well and has slowly changed the well depth from 40' to 30, and has finally reached the point where I cant fill the pressure tank without having the pump kick out. Normally you could bail out the sediment, but this stuff solidifies into a solid that I have had to break off of the pump with a hammer. I have a good well (80' deep, without the rust issue) on the property next to me, so I decided to attempt to get water from it. Trenched over 600', 7' deep, and ran 1 1/2" (to make up for friction loses on the long run) line from that well to the house. I didn't want to have to buy 600' of #8, 3 conductor wire, so utilized the existing wiring and pressure tank in the other house to feed the new line to my house. Got everything plumbed in, including a frost free spigot at the well, so I can back drain the lines from both houses when I winterize. One thing I didn't consider was the difference in elevation between the two homes, which is around 100'. When I got everything hooked up, and the pressure tank in the upper home set at 30/50 psi. I was getting 85 psi at my house. Reset the pressure switch to 20/40 and now I have 55/75 at my house. Over all it has worked out great, as I have better quality water at higher pressure, and considerably (30%) longer times between softener regeneration's. The old Ford backhoe performed admirably, but developed a bad leak at the lower radiator hose outlet, and things got really hot before I noticed. When I went to pull the lower hose, the the brass outlet piece came with it. Had about 100' of trench left to back fill, and with the nights getting below freezing, I wanted to get it finished, so I bowwerd the neighbors old 63 case to finish up. Of course I had to fix it first, bad hyd hose, but much easier than the radiator repair. Have the radiator out of the machine now, and have cleaned it out with dilute muratic acid, and have it filled now with baking soda/water. Will probably get it soldered up later today. All in all, quite the adventure. Mike
