- Apr 23, 2018
- 6,560
Flyinfool, you are correct on how cyclones work. During engineering, the height of the cyclone can be set for a particular efficiency, but ultimately it is air velocity that determines the particle size cut point. Cobbling together systems of vacuums and whatever separator you have on hand would certainly require some trial and error. Wood shops are a much better application with their big, light particles. I would prefer filtration for such fine particles as blasting debris. That's what is used in heavy industry for blasting and powder coating, you only see cyclones in wood shops.
