- Oct 14, 2013
- 995
When I made a static.converter I had to fiddle with the current sensing relay to stop it cycling/buzzing.
Sent from my SM-G892A using Tapatalk
Oh yes, I get you on that, I will be hopefully supervizin the load up as Terry said he had help.
I have been rode hard and put away wet a LOT in my life and breakdowns take a lot longer to
heal than they used to so I don't/cant push things like I used to.
If I knew I was gonna last so long I woulda taken better care of my self...................
Looks like the mill it running well.
Which DRO system did you buy. I had issues with the Chinese one I bought off of Ebay. The X axis on my lathe was not reading. They put me through a bunch of checks, then there was the lag between them asking me to check something, then checking, replying and then waiting for their response. Took almost a month for them to decide to send me a replacement. Plugged it in and all is working. But at least they stood behind it. Did charge me for the freight, but it was only $24 so not too bad. They comment was that I had had it for more than a month. Didn't matter that I spent that month installing it and then going through their checks. Oh well, all is good now.
Hadn't heard from you in a while. Glad all is OK.
Pretty much the same scenario here on the Chinesium DRO on E bay, first the screen didn't work
then a scale would make the system shut down when plugged into the screen and the almost endless e mail
tag with Shirley in china finally got all working components together and functioning.
Whilst working with it I have found that the upper spindle bearings are the noise makers needing replaced soon
not the motor bearings so the fun continues to keep me entertained and out of the wiffles hair.........................
The DRO unit is a ToAuto brand and cheaply priced, I now know why.
Time will tell if it was a bargain or not, they did make right on it though, gotta give them that .......................
