- Dec 13, 2016
- 142
Well I went with this 4 Piece Sharpening 600 and 800 grit Stone Set,
https://www.mcmaster.com/4804A12
Last few days focus on spindle assembly, drive belt and electrical wiring. Problem with belt swivel arm slop was the arm seized to the swivel stud and was rotating in the belt housing thread. Was able to unseized the arm from the stud. Locktite the stud to the belt housing and greased the stud.
Yesterday finished up the electrical wiring when my wife came out to the shop to see the progress on the mill. Decide to go head and test the mill before tramming the bed to spindle since my first project was not critical.
First project is just milling a flat spot on a piece of mechanical tubing to install a grease zerk to use as a bushing for top link on my King Kutter rotary mower. Used a 1/2” four flute HSS bit secured with R8 collet in the spindle. Adjust the belts for 800 rpm spindle speed which will rotate the bit at about 100 feet per minute. Eased the knee up to bottom of bit.
Back the vise back and raised the knee up another 0.030” for initial DOC then turn on the motor. Crank Y-axis eased the bushing into the bit slowly feeding listening and watching the chips. Crank X-axis for a second pass then crank Y-axis back. Repeat for a third pass.
Stop the mill to examine my first time milling. Impress at the finish of the milling. Obvious the bed is not perfectly squared to the spindle. The milled surface is slight tapered.
Raised the knee for next 0.050“DOC and repeat three passes again.
Backed Y-axis out and swapped the collet/bit for the R8 drill chuck with 11/32” drill bit for the 1/8” NPT tap. Chuck the tap and start tap with slight down pressure on the quill while rocking spindle back/forth by hand. Once had tap establish, uncheck the tap from the chuck and resume with the tap handle. (Shy of power tapping - discover last night you can jog the ’ON’ button).
Wow my first milling job was so natural without any problems. Thanks to today’s technology and the experts willing to share their knowledge.
A year ago, I knew what a milling machine is and it’s capability but did not know the details and nuances involved.
Thank you, Bob G.
Thank you, Bob G.
