- Feb 5, 2020
- 117
Took delivery of my new G0709 yesterday. Shipped incredibly quick given my location.
It's early, but apparently only 2 minor damage issues. Biggest is the bottom standoff for the gear set cover was broken ( easy fix when you own a lathe ). Second is probably from the first, the sheet metal spindle cove was laying wedged in the shipping pallet and slightly bent (not an issue, a rubber mallet restored it to almost new )
I do have one question though, since I had a couple hours while breaking in the spindle, I started cleaning the schmoo and while exercising the cross slide, it bound up and wouldn't move. Since I planned on disassembling and cleaning it anyway, it wasn't a big deal, but it did highlight a potential issue. After removing the cross slide hand wheel, I noticed that the key for the wheel was comically small and tilted up in the keyway causing the binding issue. It's about half the length of the shaft keyway and was lifted up at a 45deg angle binding against the thrust bearing..........is this normal? (Not the binding, the small key stock size )
Other than that, the usual issues, rough edges and finish, but smooth and solid feel. I quickly threw an indicator on the 3 jaw chuck and had .0008 indicated. Good enough for me considering it's on 4x4's sitting on car wheel Dolly's at the moment. ( another week before the intended base mounts arrive. )
huge upgrade from my 70yr old atlas 10"
I'm going to post several pics, please don't judge.......I'm stubborn and part of why this unload happened the way it did is the local equipment rental wouldn't rent me a forklift and trailer because I own a 1/2 ton truck. My trucks tow rating is 12,400lbs. Forklift and trailer combined are 10,500. (Also well within my 1634lb payload ) They would rent it to me if I borrowed my buddies 2004 Ford Excursion because it's a 3/4 ton platform, but it's tow rating is 11,000lbs........over the years I've grown very tired of this one size fits all thinking.
consequently, I enlisted my son, rented a 5x10 dump bed trailer (also hauled 4yds of gravel for my driveway), grabbed our John Deere 2025r ( no forks and only about 1000lb lift capacity) and just "winged it". Took 3hrs and several changes of the plan but we got it done. before you hammer me about the dangers.......just know that I've spent 35yrs working on ships and rigging machinery, gear and cargo so I'm not an idiot. Just stubborn. At no point where either of us in any danger, the lathe? Maybe, but not us. Granted I would have really liked to have chain falls and real lifting straps, but the ratchet straps we had worked.........just very very slowly and in one case I needed 2 so I could slack one while the other held, then slack the other. Basically a "Yard and Stay" rig with a crappy yard and stay.
