- Sep 1, 2023
- 490
I need the longer key to hold both the teethed drive pulley and the gear that goes to the change gears.Can you shorten the key or am I missing something? not that I think you will have a problem with the spindle missing a little material, I Think it is fine.
I have separated many a stuck race using a Dremel tool. If you find yourself in this pickle again try using a cut off wheel and cutting a slot in the race. Get close and use a wedge (cold chisel or old screwdriver) to break the remaining. Races are usually hard enough to crack easily when “tapped” with a wedge and hammer. Don’t forget eye protection.
The key that fits the shorter keyway on the 'unmolested' spindle only has to hold the gear that transfers the spindle movement to the change gears.
The 'unmolested' spindle is an older version, it's identical to mine in all aspects but this shorter keyway.
Hmm...maybe I underestimated the cutting efficiency of a Dremel cut off wheel? Given the lack of success drilling I dismissed the Dremel and went straight to my bench grinder.
As usual; I should have asked first on here, then acted!
