- Jan 16, 2016
- 302
I HAVE HAD THE GOOD FORTUNE OF ACQUIRING SOME REALLY GREAT TOOLS .
THIS SET OF B&S INTRIMIKS MAY BE THE BEST SET OF BORE MEASURING
TOOLS EVER CREATED .
THEY COME WITH THE MASTER SETTING RINGS AND MEASURE BORE TO .0001" ACCURACY .
AND WITH THREE POINTS OF CONTACT , CHECK ROUNDNESS AS WELL .
ABSOLUTELY INCREDIBLE .
WITH THE TOOLS & EXTENSIONS , YOU CAN SET THEM UP TO CHECK DEEP DOWN
INSIDE A BORE . IF YOU WANT TO GET A PRESS FIT RIGHT , THIS IS THE TOOL .
THE RANGE OF THIS SET IS FROM .250" TO 1.600"
