- Sep 20, 2013
- 87
I just finished the frame of my 10 ton table H press. I still have to add a transport handle and mount my 10 ton porta power to the frame. I'll be back with pictures when it's totally finished. I ordered an air over hydraulic pump for it, the pump should be here towards the end of the week. I added 1/2" steel spacers to the 4" 7 1/2 lb channels so I would have a 4" gap, the square tube risers are 3" and I didn't think that was wide enough.
I had a hard time with the C channel, the flanges weren't rolled square to each other, they were off quite a bit, the c channel's flange was so far off on one side I had to mill a slot across the flange and bend the flange downward with my big press ....and then fill the milled slot while it remained clamped to my big I beam. It was really nasty steel, it must have come from some third world Asian mill. I had to grind the heavy scale off, it was so bad my blasting cabinet which is filled with only glass bead couldn't touch it.
The pins are 10 " long 3/4" tool steel.
http://s1298.photobucket.com/user/cyberjibe/library/Porta Power Press
