- Dec 25, 2010
- 79
Hi all,
One day I noticed that I could not engage my power feed for both Longitudinal and Crossfeed. Being the amateur machinist that I am, I thought I had to take apart my apron to have look inside. I was hoping that I would see something obvious and be able to make some kind of repair by simply replacing something. That wasn't to be the case for me. What I did find out was that the 10-32 reverse thread screw that holds the clutch knob had broken and there was still a piece left inside. I think the problem was that for some reason the clutch was not functioning properly and therefore I was not able to powerfeed. I was told that the screws only function is to keep the knob from coming off so I don't think that was the reason. So I put it back together and I found that I could now powerfeed. But there was still the matter of the broken screw.
I guess I've always been a little hesitant to attempt and I know some day I'd have to learn it so I figured I might as well try it. I must admit that it took me several attempts to get it right and I'm still not sure I got it right. But at least I have a 10-32 left hand/reverse thread screw that works for what I intended it.
I did have allot of help form the guys on that "OTHER" forum. I know that most of those guys are probably on here also. The reason I'm posting it here, is because for some reason, I'm not able to post pictures with my camera on that "OTHER" website. I don't know why but I can post pics with my Cannon but it doesn't have a Macro function so I can't get any good close-up shots. With my wife's Sony Cybershot, I can because it has a Macro function. But for some reason, I can't post pics on that "OTHER" website's forum.
The problem I was having with the threading operation was that the dial on my cross slide was unlocking and giving false readings. I was breaking the .186 piece that I was threading. ... I think.
Maybe all this is laughable to some of you guys but I think this was a great learning experiance for me.
