I've got a little tiny knick inside my TS. I tried a little high grit paper to just touch it but to no avail. The machine is almost new. Also thought about the reamer but man I don't want to mess it up.
I did the same thing with the spindle bore on my Atlas 10F several years ago. Ground down the high spots with a Dremel, then followed with roughing and finishing import reamers. I did the reaming freehand without using the tailstock to hold the reamers. It took a long time, but eventually got there.I did a clean-up on my Atlas spindle and tailstock tapers with Russian reamers. The spindle and tailstock material was very hard, and it was rough on the reamers to simply clean the tapers up. It worked great, but any more than a micro clean-up would have destroyed the reamers. You might need to anneal.
I have one coming but will let you know if it doesn't work out, USPS flat rate really makes this kind of stuff easy. If anyone needs "single use" tools like this I think we should really take advantage of this forum. Everyone I've met on here is definitely the sort I'd lend a tool to....I did the same thing with the spindle bore on my Atlas 10F several years ago. Ground down the high spots with a Dremel, then followed with roughing and finishing import reamers. I did the reaming freehand without using the tailstock to hold the reamers. It took a long time, but eventually got there.
John: If you're in CA now, or want them sent there, I might be the closest to you postage-wise. Let me know if you want to borrow the reamers. Bill
View attachment 377749View attachment 377750
