- Mar 22, 2023
- 129
I will be unloading the lathe from a car trailer into a spare bed room .
I have no choice but spray the lathe with solvents and denatured alcohol. to get the oil off.
Before the lathe is loaded i will remove the motors shielding and the motor.
Before thee lathe goes in my home i will remove the carriage cross slide and tail shaft and the stand just make.
I covered the bedroom floor with 1 inch plywood
The lathe is about 540 pounds
Trying to remove as much weight as possible .
1 inch 2x4 pieces of plywood to lay down on the floor to roll or slide the lathe on.
The lathe is 17 inches wide with motor and guard removed.
My shop is not temperature controlled , this why bought this lathe.
This link shows photos of a Logan lathe like mine
If any of you have some foresight on me moving this lathe without anyone or anything getting hurt and ME not breaking the lathe. that would be great.
I have already remove 3 lathes out the spare bedroom
