- Sep 28, 2013
- 4,316
you can still do exactly as you propose, but by making a threaded stub arbor you can now easily hold the flywheel on your lathe - should have thought of posting a picture but I was in a hurry
you can just see the end of the arbor with the 60deg center drilled in the end of it in the 1st pic. That's an Atlas 618 so I'm pretty sure it would fit on your lathe, even if it's a 7x14
