- Jan 23, 2012
- 1,216
I recently aquired a used rong fu 30 mill and felt helpless with out a dro like i had on my previously owned bridgeport. So after a little consideration, I bought a 36 inch long, DRO, mag strip type with the remote readout on ebay. . .. you know, the one for $59 delivered. I figured that i'd put that much in beer in just a few weeks so if it would work, great, if not, a great learning experience. I could not put the pictures in order with the story but. . . <o></o>
the dro showed up about 5 days after ordered, un-harmed and very well packaged. These are three sizes i have ordered.<o></o>
<v:shape id=Picture_x0020_3 style="HEIGHT: 258pt; VISIBILITY: visible; WIDTH: 450pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1030"><v:imagedata o:title="digital remote dro (600x344)" src="file:///C:\Users\%60\AppData\Local\Temp\msohtmlclip1\01\clip_image003.jpg"></v:imagedata></v:shape><o></o>
The mounting hardware furnished is just about the same as came with the glass scales I installed on my bridgy a few years ago. . . pretty dang universal, so i expected i’d be custom making whatever i needed for my application and i carried on. <o></o>
Kind of knowing what i was in for, i pulled out the small drills and taps and allen screw assortment and started in, drilling two holes in each end of the table,, about where I figured the scale should mount. Of course my measurments were not quite right so it ended up not quite where i wanted it, but this was a custom mount so i felt i would be re-doing stuff as i went along.<o></o>
<v:shape id=Picture_x0020_4 style="HEIGHT: 351pt; VISIBILITY: visible; WIDTH: 468pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1029"><v:imagedata o:title="dig4 (800x600)" src="file:///C:\Users\%60\AppData\Local\Temp\msohtmlclip1\01\clip_image004.jpg"></v:imagedata></v:shape><o></o>
I sawed off the leg of the bracket. I only wanted the part with all the tapped holes in it for the fixed reader part.<o></o>
I located the scale or whatever its called is about ¼, maybe 3/8 inch below the top of the mill table and it was a little too long too so I sawed it off with a cutoff wheel. Perfect.<o></o>
I put it on the mag strip or scale and start measuring for the reader mount that needs to fix solid to the lower, not moving part of the table.<o></o>
Ok, this should not be a problem. There are already two holes for the bolts that hold the skirt that covers the “y” axis ways & screw. If i can make a bracket to use those holes, and still be at the right spacing at the back of the slider, that would be super. <o></o>
Well after some minor engineering and modification of the bracket that came with the unit, i had it. Great.
Now take it all apart and make the guard that covers the scale and slider and all, to protect it from swarf and stuff. <o></o>
The guard needed to be the first part installed as it is between the scale and bolted to the back side of the table.<o></o>
<v:shape id=Picture_x0020_7 style="HEIGHT: 351pt; VISIBILITY: visible; WIDTH: 468pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1028"><v:imagedata o:title="dig9 (800x600)" src="file:///C:\Users\%60\AppData\Local\Temp\msohtmlclip1\01\clip_image006.jpg"></v:imagedata></v:shape><o></o>
<o></o>
Finding proper material is always the biggest part of a project for me. Im here in a place thats 30 miles from any kind of metal suppliers so i have salvaged and saved a bunch of “junk” as my wife calls it, over the years. I found a couple of options. Sheet aluminum from and old sign that was about ½ as long as i needed but i could make two and just butt them together, or a pc. Of galvanized sheetmetal from back side of a kitchen range that was in the scrap heap. I figured i would make both into guards and choose which one i would use after i see how they worked out. <o></o>
So i cut those to size with the plazma, used the box and pan brake and bent them into a un-equal legged channel about 1” between the legs. I think i measured ¾” to the first bend line, 1” farther to the next bend line and that left 1-3/4” for the vertical leg. the 3/4 leg would screw to the back of the table with 4 small screws.<o></o>
<o></o>
First, i did the aluminum guard. I figured out that if i used two 6-32 allen screws in each of the short legs about 1” from each end, i could punch the holes for the screws first, then locate and punch a larger set of holes in the opposite or 1-1/4" outer flange so i could get a allen wrench to the mounting holes. After the punching i marked the first hole in the back of the mill table, drilled and tapped and installed the first fastener. with the first half of the guard mounted on one end and i could easily locate, drill and tap the second hole and continue with the other half of the guard and see how it came out. The top of the guard is still below the top of the table and the guard is the highest piece going on rear edge of the table. <o></o>
Ok, im done with the guard and its mounted, now lets install the magnetic strip or scale under the guard and see how.................................. crap, now its too close and the screws and slider try to occupy the same space. I screwed around with the brackets a bit and put flat head machine screws where the guard mounted to the table and now thats fine but now the end brackets are at the end of their slot and i need to space the magnetic strip / scale out just a bit more. <o></o>
Well, i made new end brackets, drilled and tap the holes for the fasteners, then i slotted these little rascals with my new mill a little longer than the orig ones. New longer slotted brackets fixed the interference. Whew.<o></o>
<v:shape id=Picture_x0020_10 style="HEIGHT: 624pt; VISIBILITY: visible; WIDTH: 468pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1027"><v:imagedata o:title="dig6 (600x800)" src="file:///C:\Users\%60\AppData\Local\Temp\msohtmlclip1\01\clip_image008.jpg"></v:imagedata></v:shape><o></o>
<v:shape id=Picture_x0020_11 style="HEIGHT: 351pt; VISIBILITY: visible; WIDTH: 468pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1026"><v:imagedata o:title="dig7 (800x600)" src="file:///C:\Users\%60\AppData\Local\Temp\msohtmlclip1\01\clip_image009.jpg"></v:imagedata></v:shape><o></o>
I finished mounting everything, even the orig. plastic skirt that covers the ways. I have lost a little “y” travel but should be able to live with that. <o></o>
These little DRO’s don’t perform any fancy mathamatics, they just tell you where you are so you can get back to wherever that is, easily. my eyes are crappy, its always too dark, too close or too far away to see where anything is. this will relieve that issues.
It seems to be fine, works smoothly, and i was so impressed i contacted the import company and signed up to be a distributor for their products. . . .to buy quanitys at wholesale prices.
i have a galvanized metal guard for anyone that wants it to do the same conversion. Its 30+ inches long and will fit in a mailing tube im certain. Just pay the postage. <o></o>
I have my distributorship approved and i ordered a bunch of dro’s to share with anyone interested. You would need only a sheet metal guard made for it, which I could probably do or an easy piece for a local sheetmetal shop or it could even be made of thin plastic or the like. Possibly a couple end mounts like i made too. it depends on what and how you mount them.<o></o>
These are the prices of these remote reading units.<o></o>
12” long 23.00<o></o>
24” long 30.50 <o></o>
36” long 35.50
This is plus whatever it cost me to ship them to you and i have not gotten a figure yet from the usps. I should have that the first part of next week.<o></o>
These magnetic strips / scales can be cut to length without harming them and have a 60 day warranty from my supplier. Common sense would tell you they are not something to whap with a hammer or soak in liquid. <o></o>
They are soo low priced that i think everyone should have one or more. Im going to fit a couple on my 12 in craftsman lathe too if I can. My eyes are not the best anymore so the dials on the cranks are difficult to read. I will document my progress on the lathe for future inquirys. .<o></o>
I also ordered box of digital angle cubes. They are so cool. <o></o>
<v:shape id=Picture_x0020_12 style="HEIGHT: 226.5pt; VISIBILITY: visible; WIDTH: 274.5pt; mso-wrap-style: square" type="#_x0000_t75" o:spid="_x0000_i1025"><v:imagedata o:title="digital cube" src="file:///C:\Users\%60\AppData\Local\Temp\msohtmlclip1\01\clip_image011.jpg"></v:imagedata></v:shape><o></o>
<o> </o>
They measure angles for comparasion checking or whatever. Someone mentioned them a few months ago so i got one for myself. I use it for setting table saw / hand saw blade angles, and when i need to figure angles for locating a pc of steel in the vice of a mill. . . .or tool grinder. <o></o>
They are only $21.30, again plus postage. I know i paid $30 plus shipping for the one i bought about a year ago.
for clarity sake, the pictures are as follows. . .
1 the mag./ strip or scale
2 my new to me, mill
3 the remote reader
4 the end of the table where I drilled and tapped to mount the scale bracket
5 the partially cut off bracket for the fixed head on the scale
6 the guard laying on my table
7 the left end of the table with guard attached
8 the split in the guard. its two halves as my material was only 16" long and I needed to total 30"
9 the readout / control, just slapped on the side of the mill. mag base on it.
10 & 11 the three dro's and the angle cube I ordered
Whew, i need a beer. . . .<o></o>
Private Email me if your interested.<o></o>
<o></o>
<o></o>
36” long 35.50
<o> </o>
3 the remote reader
