Motor wired for high voltage
Pevehouse
H-M Supporter - Gold Member
Oct 27, 2023
363
Hi all, I purchased a used 2 hp 3ph motor for my lathe upgrade. It currently has a 1 hp 3ph on it and I figured it wouldn’t hurt to add an extra horse. Problem is the guy I got the motor from told me it’s witred for high voltage and I would need to rewire it for my 220 . Never done anything like this. Is it complicated? I will post some pictures of the wiring when I get home. Thanks in advance
As long as it has 9 wires in the pecker head, and they are properly labeled, you shouldn't have any problem. There might be a diagram something like this on the side of it.
High voltage = 440, Low voltage = 220.
I will look when I get home. Would be nice if there were a diagram. Best I can recall it’s just a wad of wires in the pecker head,lol
Just know that this wiring is standard. The numbers are all the same. They may be printed on the insulation or they could be crimped on, or even paper labels. But the 1 through 9 is standard.
One caveat. This is for a Wye connected motor. Delta connected motors are different, but they are much less common that Wye.
