- Mar 12, 2022
- 132
If you don't alredy own a copy, you should get Ted Hansen's book "The Complete Mini Lathe Workshop".There are a lot of good ideas for 7x lathe improvements there. Ted has also reported (in the faceBook 7x group) on some experiments he did to measure the flex of the ways in the Sieg 7x lathe. His results indicated that flex in the ways was not a problem - especially compared to the many other sources of 'looseness' in the 7x - so that bolting down the lathe wasn't necessary. So bolting to heavy bases and filling the ways with concrete should probably go to the bottom of the list. Squealing and chatter while turning can have several causes- you're already addressing one of them (compound looseness).One thing you may already be aware of and may have made modifications to ameliorate, is the lack of built-in rigidity in the Chinese 7x14's
