    Dismiss Notice
Motor Capacitor Replacement ?s
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by Splat, Aug 30, 2017.
  1. Splat
    Splat Active User H-M Supporter-Premium
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Guys, I need some help here please. My G4003G lathe's motor started slowing down while taking a really light cut the other day. Yesterday I go to start the motor at the 1400rpm setting and it wouldn't spin up unless I helped it. I spins up fine on slower settings tho. I'm thinking it could be either both start and run caps going bad or the motor itself. The motor seems to run and sound fine so I'm hoping it's the caps. The start cap is the one I'm unsure which to go with. The start cap is 150uF, 250V. McMaster has two ranged caps that might work, this 130-156uF cap, and this 145-174uF cap. I don't know which is the better bet to go with. Thanks.
  2. markba633csi
    markba633csi United States Active Member Active Member
    402
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Sounds like just a bad run cap- very slim chance both run and start caps are bad at the same time unless one of them was on the way out and the other one just caught up with it...
    Mark
    ps just checked the G4003 manual and the run cap is a 20 uF 450 volt unit.
    As to your question about cap sizes, I would pick the larger one of the two. Make sure the voltage rating is equal to the original or larger.
  3. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Thanks Mark. I'll try the run cap then first and see what happens.
  4. markba633csi
    402
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    OK. Check physical size to make sure the replacement will fit in there
    Mark
    Ulma Doctor likes this.
  5. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,027
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    you beat me to it mark! ;)
    Silverbullet and markba633csi like this.
  6. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    I'll duct tape the darn thing to the side of the motor if I have to. :)
    markba633csi and Ulma Doctor like this.
  7. Ulma Doctor
    3,027
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    if you have a hard time gettin' a cap, i got one i can send to you brother
    darkzero likes this.
  8. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Thanks Mike. I ordered one from McMaster. Yet another thing to work on this weekend.
  9. mksj
    mksj Active User H-M Supporter-Premium
    1,435
    113
    City:
    Tucson
    State:
    Arizona
    -Return to Top-
    I would replace both as they both deteriorate over time, as others have said check the size as they are often not a uniform size. I believe the ones from McMaster may be too large for the G4003G motor. You can also check pool repair shops, often the pump capacitors may be smaller. I had another machinist bring over his G4003G motor that stopped running, pulled the start capacitor and tested it DOA. The electrolytic capacitors go with time, the start is most common from overheating with frequent start/stops. Usually the lower uF higher voltage are film or oil caps. I have replaced my share in various motors capacitors out here in the hot desert, nothing seems to last with the heat.
    On the G4003G motor capacitors on the one I saw the wires went directly into the motor, so you will need to cut the wires and use wire nuts or some form of insulated connectors. A number of people have also replaced the motor.
  10. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Well, I could make another set of covers for them. I just looked up the caps part #'s on Grizzly's site and the one's from McMaster are a little bigger so I may have to make covers for the new ones. We shall see.
  11. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,526
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    I agree with Mark, might as well replace both while you're at it. I read that the start caps are usually the ones to go out first. Cheap ones don't have good duty cycle so if you are doing a job where you have to turn & off the machine repeatedly you eventually blow the start cap.
    Sure enough, that's what happened to my mill some years ago. Start cap blew during a production run I was doing. My lathe has the same motor as my mill & it's older but surprisingly it hasn't blew a cap yet. If you have a multimeter (even better if it can measure capacitance) you can check if the cap is bad. Sometimes the caps will also show physical signs of failure, like bulging or cracks, depending on the type of cap.
    I don't know much about AC motors so I wasn't sure about ordering caps from Mcmaster at the time since they listed a uF range. Don't see that in DC & is what I'm used to. I ended up finding the exact values & physical size at Grainger. Weren't too expensive & I was able to just drive down to pick them up the next morning.
    They were their house Dayton brand & at first I was worried cause they were made in China. But they looked nice & had metal cases. As mentioned, I had to cut the wires on the old ones & I installed spade connectors as that's what the new caps had. That will make future changes quick & easy.
    Weird thing is the stock start cap was made in China & the stock run cap was German, both with plastic cases. I replaced both & haven't had a problem since.
  12. darkzero
    1,526
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Ah well I take that back, memory not too good anymore. I found the pics I took. Only the replacement run cap I got was a metal case but I have no idea it that even matters. Looks like my caps are the same value as yours. Here's what I had, again they fit inside my covers just fine. The stock caps barely lasted me a year & it's been 4 years since I replaced them. (I forgot how ugly that motor was painted white, yuk, I painted the motor black when I changed the caps).
    Ulma Doctor and Splat like this.
  13. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Thanks Will. They're probably the exact same caps I'm gonna get from McMaster, but branded otherwise. I know about caps via DC (I've built circuits in the past) but wasn't too sure of them pertaining to AC motors. But, this is how we learn. I'll get mine on Friday. We shall see.
  14. darkzero
    1,526
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Yup same here, I worked in automotive & electronic repair. I'm not very familiar with AC motors. But at least when that happened I now know what the centrifugal switch looks like & how it works. And good thing there's plenty of guys here that are knowledgeable & helpful.
    I assume the caps from Mcmaster will be good quality & they don't sell China stuff that is junk. As long as they fit you should be good.
  15. darkzero
    1,526
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Oh BTW, be careful when changing those caps. Make sure they're denergized first! Search online on how to do so or the guys here can recommend a safe way. Don't do like I do with a screwdriver.... ;)
  16. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Oh yes, I learned that cap drain lesson long time ago. It was a ....shocking moment. :p You definitely do not forget those lessons quickly. BTW, I first thought the centrifug switch was the culprit. It still could be but I doubt it. I thought of going to 3ph VFD setup but it'll have to wait. I'll be happy to have the lathe running properly again.
    Ulma Doctor and darkzero like this.
  17. JPigg55
    JPigg55 United States Active User H-M Supporter-Premium
    132
    63
    City:
    Smithfield
    State:
    Illinois
    -Return to Top-
  18. Blackjackjacques
    Blackjackjacques United States Iron Registered Member
    3
    3
    City:
    Fairfax Station
    State:
    Virginia
    -Return to Top-
    Either of the two will work fine, particularly since the tolerance of standard electrolytic capacitors are 10 to 20%. The more important paramter is the working voltage - if the old cap is 250V, you will want a cap 250 V or more -- but never less.
  19. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Yep. I've always went by the 20% rule with caps, though that's for general use. For tight tolerances in a circuit I use 10% or less.
  20. Doodle
    Doodle United States Active Member Active Member
    39
    18
    City:
    Gulf Breeze
    State:
    Florida
    -Return to Top-
    If the motor has enough age to have a cap failure, if it isn't a big effort, good time to check bearing lube, smell inside the motor to see if windings got hot. Sometimes the windings change color from the heat too.
    darkzero and Ulma Doctor like this.
  21. Ulma Doctor
    3,027
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    Believe it or not, there is no storage of AC voltage possible in a capacitor.
    the capacitor stores and releases the voltage as a DC conductor only.
    so when we use capacitors in an AC circuit, the caps charge is DC and we introduce DC power into the AC system.
    Kevin J and darkzero like this.
  22. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Finally got the time to replace the caps. There's no schematic or circuit drawing on the cap or inside the cap covers so I can't tell which lead is which. I guess I'm used to DC polarized caps, guys. Are these run and start caps non-polarized (doesn't matter which lead goes to which cap pole)? Thanks guys.
  23. darkzero
    1,526
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    AC, non polarized so it doesn't matter.
    Splat likes this.
  24. Splat
    114
    63
    City:
    here and there...
    State:
    New Jersey
    -Return to Top-
    Sweet. Thanks Will!
  25. Linghunt
    Linghunt United States Active Member Active Member
    49
    18
    Santa Rosa, CA
    City:
    Santa Rosa
    State:
    California
    -Return to Top-
    I replaced the motor on my compressor a while back and left the old one in the corner. Local scrap guys picked it up a month ago or so.
    I should have pulled the capacitors off of it 1st, but didn't even think about it till now. Windings were all smoked on it so not a cap failure. Anyhow just a note to think about that if you are tossing a motor.
Share This Page
