    Dismiss Notice
Most useful upgrade for my Hitorque mini mill 3960.
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by Ken from ontario, Feb 2, 2017.
  1. Ken from ontario
    Ken from ontario Canada Active Member Active Member
    154
    43
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    I am getting tired of banging my knuckles locking /unlocking the spindle drawbar so I think the most urgent and easy to make project would be to machine a spindle lock for it, am I the only one feeling the need for such a contraption?
    I am left handed ,maybe that has something to do with it,at any rate, there's a spindle lock I'm following on youtube that is easy to machine and anyone with a little milling know how can do it.
    Has any of you ever bought the ready made spindle lock by MLS ? they also sell an updated version for the 3990 that has a magnetic lock, now that would be a nice one to have but a shopmade type would cost me next to nothing.
    rdean likes this.
  2. master of none
    master of none H-M Supporter - Premium Content H-M Supporter-Premium
    36
    18
    City:
    Brooksville
    State:
    Florida
    -Return to Top-
    I made one and it was very easy just take your time watch the vid and go for it.Mine made a world of difference .
  3. Ken from ontario
    154
    43
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    Good to know it worked out for you, It sure sounds like a very interesting project for both hobbyists and the pros ,when put to use, it should make a significant improvement.
    Thanks for your input.
  4. Ken from ontario
    154
    43
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    I am half way there,made the block , drilled the 3 holes but since I don't own a lathe I can't make the pin the same way as the video , instead, I 'm using a threaded rod that fits in the spindle hole,which means when I need to change tools I just thread the rod in the hole to lock the spindle but the drawback is I must remember to back it out before tuning the machine on.
    How did you make the pin? did you drill a hole with a split pin in it to hold the spring?
  5. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    838
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    Non sequiter.
    Non sequiter.
    I had a lathe for three years before I got a mill. I never even possibly imagined an opposite progression.
    Ken from ontario likes this.
  6. Ken from ontario
    154
    43
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    I know it doesn't sound logical but I'm also a hobby woodworker and my milling machine act as a glorified drill press,lol.
    my old DP speed only goes as low as 300 rpm but this little mill has lower RPM and high enough torque for a lot of woodworking tasks such as using forstner bits,etc.
    . I'm seriously planning on opening some shop space to accommodate a small metal lathe :chunky:
  7. llamatrails
    llamatrails Iron Registered Member
    3
    3
    City:
    Gainesville
    State:
    Georgia
    -Return to Top-
    Might be a bit late here, but I also don't have a lathe (yet). So, I will adapt the spindle handle/pin that came with the mill to replace the bolt in Charlie Sarsfield's plans.
    Rick
Share This Page
