Hi Bill, I wasn't so much interested in the gear calculations, which I can do, but whether certain modules are more commonly found than others. For instance, it seems to me that reading about various projects on the Internet, Module 1 seems to come up a lot.I used to know that answer. If I remember correctly it depends on the size of the teeth you are trying to cut. The gear diameter will depend the number of teeth. Sorry I never cut gears in the shops I have worked in. I have bored out the inside diameters before on commercial gears to match the worn/broken ones.
Hi Everyone,
I suspect this is a daft question, but is there a gear cutter module which is most commonly used?
Regards
Xiansheng
