I weld them out. Easy out type things only work on stuff that stripped or broke due to defect or improper tool used on it. If it was stuck enough to break off then an easy out aint gonna cut it. Welding has always worked VERY well for me and does not come with the need of precision like drilling out does nor the risk of damage. The key is to weld slow so the heat can penetrate. Tig welders are best, especially for those broke of below the surface a bit.
