- Feb 26, 2014
- 257
Next up is the installation of Igaging Absolute Dro’s on the lathe. On the cross slide the reading head is fixed and the scale moves. The carriage travel head is mounted to the same bracket that holds the display units, which means all the cables travel with the carriage to keep them tucked in and well protected.
The original lock on the tail stock takes a good full turn or more to tighten, and I wanted to reduce that to just 1/4 turn. Browsing through McMaster and Carr I found and bought a 1/2”- 6tpi coil threaded nut and bolt. After replacing the original bits and a bit of futzing around to get everything set I can now tighten and loosen the tailstock with less than 1/4 turn.
For future improvements I would like to do include an extended T-slot cross-slide from Metal Lathe Accessories and a rear parting tool.
Bill
Bill
