- Apr 10, 2021
- 593
Worked some more on the clutch today. Not without drama as part of it was frozen on the shaft so I had to make a part so I could use a puller. You need a lathe to fix a lathe. I have a question regarding snap rings. The clutch has two bearings, each held with a snap ring and a spacer between them. The front side ring is flat on both sides but the rear ring has a bevel on one side. That bevel was on the outside so the flat is against the bearing. I'd like to verify that is correct. Old bearings were pretty decent. Way too much grease but at least it was still grease and not rock. Dave
