The 9A I just bought needs to be moved to my garage, and the plan is to carry the stripped cabinet home on my lifted, off-road utility trailer. The trailer sits high enough that any sort of ramp is not practical. There is an I-beam running across the garage ceiling that I use to lift stuff from, so the trailer will be backed underneath and a come-along will be used to lift the cabinet and the trailer then driven out.
I am designing a spreader bar of sorts to bolt directly to the tray of the cabinet, using the lathe mounting bolt holes. Measuring the hole locations is imprecise with the frame/ways still in place, which I can't remedy at the moment. Is anyone aware of a schematic that shows the hole spacing for the 9A with 4.5' bed? Thanks!
