- Apr 30, 2015
- 11,376
Wow that's an unexpected (and welcome) repair- good deal
update just came in from shop . i am happy to report that the lathe is fixed. the motor had a stuck brush. having some knowledge of dc motors i was able to repair it.the control board seems to work fine during cutting the piece would walk out of the chuck increasing the feed rate this loaded the lathe to an extreme,causing over heating.
im thinking that i should grind the jaws of the chuck however runout is not excessive. maybe its time for a better o
while boring a 1 in recess for bearings for live center i think iv killed my mini lathe. belt has shredded about the 4th time in about a year. motor will not run, and some evidence of hot wires around the speed control. very sad , i think i broke my toy.
Ah, the direct approach....after the first lucky repair tried again motor over heated really hot and quit . it is killed and the control also. repairs are now complete. see conversion. a 6ln. pulley is coming . this is a 1 hp motor from harbour freight. now we have power and multi speed control. the little crank controls the belt alignment and just visible on the far left is the belt tension adj.
You should have plenty of torque now!after the first lucky repair tried again motor over heated really hot and quit . it is killed and the control also. repairs are now complete. see conversion. a 6ln. pulley is coming . this is a 1 hp motor from harbour freight. now we have power and multi speed control. the little crank controls the belt alignment and just visible on the far left is the belt tension adj.
