- Mar 19, 2014
- 2,681
Hi nuturner, I've done a bit of lathe milling and as has been said you need to tighten everything up and adjust carriage gibs very snug. Also adjust the gibs in the milling slide very snug.
If you are moving the cross slide lock the milling attachment with one gib screw, likewise if you're moving the milling slide lock the cross slide with one gib screw.This will eliminate lead screw slack in the non moving part.
Best not to use the carriage wheel to move the carriage towards the chuck, engage the half nuts and turn the lead screw by hand to advance the work onto the cutter, this gives much smoother control but may involve cobbling up a crank handle on the end of the screw.
As has been said a collet or at least a Jacobs chuck should almost eliminate an intermittent cut and will feel smoother.
I'm sure there's more I could add but it's been a while since I used mine, don't give up, I managed to make this using a milling attachment for quite a lot of operations.
http://www.hobby-machinist.com/show...a-new-apron-gear-case-10F-11-using-lathe-only
Bernard
Now using a Jacobs chuck to hold an end mill/cutter can be a problem. The typical drill chucks jaws are tapered down to a very narrow jaw grip, some go to a wedge/chisel point (the chucks that close to “0”). They are almost worthless for holding anything that will involve a side thrust load. If the chuck was subject to a side thrust load. The jaws would instead act like 3 chisels and your part/tool will wiggle loose. A collet on the other hand, has just the opposite in surface contact for holding. It’s an excellent choice for side thrust loads…Good Luck.
