- Nov 25, 2015
- 8,342
expanding on this idea,...I would consider putting a tight fitting wooden dowel right thru the tube before cutting any slots.
When using either the mill vise or clamping to the table, it will help avoid collapsing the tube.
-brino
take the dowel cut it at an angle like an adjustable parallel.. sand it, put a piece of thin wood the size of the saw kerf in glued to one side.
put it in the tube, and squeeze it from the ends, it will hold tight. use a clamp, or tail stock ..
just a thought.
