- Jul 28, 2017
- 2,386
An interesting idea. One issue that comes to mind is that the narrow strip might fall into the saw slot. A zero-clearance slot, much like a standard table saw, would address that.I have to cut a lot of 0.02" strips from 0.02" brass sheet, thinking of making a "table-saw" style plate of 1/4" aluminum to mount on the lathe cross-slide with a slot for the slitting saw, cut freehand with a fence - any shortcomings in such a setup?
Since the table would have to be fixed you'd need to move the fence in .02" increments. Depending on your lathe, you might be able to come up with a two-piece arrangement where the table is attached to the cross slide and the fence is attached to the compound. The attachment points for a traveling rest could come in handy for that.
De-burring the metal might be challenging, if burs are an issue for your application. .02" wide strips wouldn't be too easy to handle.
I'd love to see what you come up with. Keep us posted!
