I have an older Millermatic 35 welder. It's set up for .030/.035 wire. I am considering purchasing the updated gun kit that can accommodate .023 wire however I have to figure out how to retrofit .023 drive rollers. I have two spare OEM rollers. Looking for ideas as how to make these work. I thought about applying JB Weld around the grooves and then machining it back to OD of the roller. Then machining .023 grooves. Any thoughts out there?
