How old is your boring head, and how is the bar secured? Heads do wear with age. Often times if the tool isn't secured tight enough (usually 2 set screws) either the tool will move in the head, or will cause enough vibration that the position of the slide will actually change.
Try making a few more cuts paying close attention to the scale when starting a pass and look again before retracting it for a second pass. If the scale hasn't moved you could have a problem with the bar moving in the head, or actually flexing. I know larger heads can withstand cuts as deep as .040" per pass. However I believe that's way too much for a 2" head. The maximum depth of cut I would make is .020", (.010" is more reasonable with cheap Chinese made sets) with several passes on the finish cut at a maximum depth of .005".
I would also use the shortest, thickest bar available to minimize the chance of deflection.
As for the mill, if there is runout it will be magnified the farther the quill is extended. To minimize the runout I would retract the quill as far as possible, and raise the table to bore the hole. It will take a little practice to get a mirror finish, but it can be done.
I also use the bars pictured in John O's post. Often times they come from the factory poorly profiled. I have seen them have little or no cutting edge, tapered in the wrong direction with the cutting edge on the top, and on one set the steel backing bar was extending beyond the carbide. There are some US and German made sets that are much higher quality. They do however cost considerably more.
