In the middle of a clean, paint and rewick of my new to me Heavy 10l. Tailstock is done, and most of the cross slide and compound are done. Just got the apron and saddle off. I want to have the saddle up back together before starting on the apron so I have a clean work area before I start. So far the only missing piece is the compound jib adjust screw, I may have to make a new one.
I have found 3 questions in my rebuild so far.
1. What is a safe way to clean the ways? I was thinking wd40 and 000 or 0000 steel wool, but I know this isn't a hardened bed
2. The nut behind the star wheel clutch - should it be tightened against the apron or the star? Mine is loose and the rebuild book is pretty much based around the lever type
3. Should have the rest of the wiring supplies soon. I am assuming these old motors have a cover/box for the connection to the motor leads. Any trick to wiring it up without removing the motor?
Thanks for any assistance. So far it's not been too bad. Seems the last owner liked to paint far more than machine, so most of the work has been removing 5+ layers of paint.
