- Feb 1, 2015
- 9,605
If you wanted to move the read head at a steady pace, a length of threaded rod would be sufficient. Thread pitch accuracy wouldn't be an issue. The glass scales that I have used come with a calibration certificate but for best accuracy, they needed to be calibrated in situ and a scale factor used. I used a 6" bar to calibrate mine as it was the longest bar that I could measure with my micrometer set.The "meter long" lead-screw, if used, would just be to move the stage over the full length at a steady pace via a stepper rather than by hand, out of fear of missing steps in the scale. But as you say a small lead screw could be used as long as it can be slid into position, hence my comments about maybe just using a micrometer for those last few mm.
By "backlash" (probably not the most appropriate term), I meant any potential movement in the mechanism between the microscope and the scale, like if a force is applied during use. Some is inevitable no matter how rigid (and I don't expect to be able to put in the time and expense to achieve lathe-like rigidity), and almost any would be in the micrometer range.
I can't calibrate the scale without some other scale that is also about a meter long. Ringing together a whole bunch of gauge blocks would probably accumulate small errors, but it's a thought. I don't know what other physical reference could be used. NIST probably has an actual, physical, meter-long meter in a vault, if only for historical reasons, but I doubt they will let me borrow it. ;-) Calibration of a scale is presumably done at the factory via optical means (e.g. laser interferometry), or at least one hopes, but with cheap scales, probably not?
One thought regarding your calibration. If you made a suitable bar of arbitrary length, you could send it to a certified metrology laboratory. A simple calibration like that would be fairly inexpensive and then you would have a NIST traceable standard in hand. They should be able to calibrate to the same standard they use for gage blocks which should be to a microinch at worst.
