- Nov 5, 2016
- 1,419
Can you rotate the sleeve (the barrel in your diagram) to calibrate? It may be just a friction fit and allow you to rotate it to zero it.
Good luck,
Ted
Good luck,
Ted
Thanks, I wondered the same so I tried it both directions - no movement. But I will try the other micrometers to see if anything moves.It may be left-hand threads.
Thanks, I did try that. I applied as much force as I thought necessary (in both directions), with no movement. Maybe it just needs more force but I'd prefer to explore all other possibilities before attempting that. Honestly it isn't worth ruining them, I could just compensate my measurements by the amount they are off if nothing else works.Can you rotate the sleeve (the barrel in your diagram) to calibrate? It may be just a friction fit and allow you to rotate it to zero it.
Thanks. I saw that page while researching this. Unfortunately it did not have any information regarding these particular micrometers or anything like them. I'm now of the opinion these were not big sellers (I've found absolutely no mention of them on the web). It could be quite possible they did not sell because they are not adjustable??Here a page showing various makers.
I believe this is what "RJSakowski" was saying previously when he posted this - "I suspect that the two knurled sections on the barrel unscrew to reveal the adjustment."Can you unscrew the base part of the ratchet screw from the end of the thimble?
Thanks for your picture. As I stated in my last post I do not think mine is exactly the same, but it helps to see the parts separated on yours for reference.I'm going to start soaking the spindle/thimble assembly in penetrant for a few days, then maybe try an ultrasonic cleaner.
