- Nov 16, 2012
- 5,596
Hi...
Just out of curiosity, do you need "lathe precision" on these tubes you are cutting and facing? Also, when you say facing, do you mean side cutting or, are you simply squaring-off (facing) the end? Maybe there is some other machine to address this.
As far as Asian lathes that I carry through Precision Matthews, both styles (US and Metric) are based on the same frame, same internal gears etc. The differences are accounted for only by the dials, labeling and the three main screws (lead, compound and crossfeed) in the system. Even the change gears you get will be the same -just different instructions on how to use them.
We recently had a situation whereby the factory sent us a bunch of metric machines and a handful of them accidentally got shipped to customers. The factory is sending a change-over kit (which by the way folks, is due to arrive in PA in about 10 days) which will take about an hour to install.
I'm not aware of any manual, current production machines capable of the bore size you want, with a bed length in the 500mm (20") range. LOL, you could of course consider this http://www.hurco.com/en-us/cnc-machine-tools/turning-centers/lathes/Pages/General-Purpose.aspx but, it might be more than what you're looking for .
In times past, Matt was able to special order a metric lathe as the request comes-up once, maybe twice every 3 years. The problem now, is the factory has a minimum purchase of 10 units. In the last shipment, he requested 2 units -which was interpreted as 2 x 10 (20 machines) as that's how many showed-up. Going forward, he can order the individual parts but I'm sure there would be terms on the sales agreement.
Ray
EDIT: I fixed an unclear sentence.
Ray
