- Oct 13, 2012
- 175
My CNC'd X3 (using CNCFusion's kit) is 98% metric bolts and measurements. I find I need to drill and tap mounting holes in a piece that anchors the Y-axis ball-nut to the base of the X3. Oddly, I have never contemplated metric drills, taps, or hardware. Is there such thing as a set of metric drill bits? What would be a good size set to pick-up?
I already have a 115pc standard set of drill bits. Is there the equivalent for metric?
If I was going to pick-up taps to have on hand, what sizes would be good to start with?
When I buy hardware (nuts, bolts, screws) I tend to buy a whole box when I only need a handful. That way I have build up a stock of hardware to use in the future. Like the question on metric taps, what sizes and lengths would be good to build up?
I expect I'll be focusing mainly on socket head hex screws and bolts. What grade would be appropriate for use with modifications, repairs, and maintenance of metal working tools (mills, lathes, etc.)?
As always, answers, comments, and factious remarks are appreciated.
