I uploaded the spreadsheet as a zip file in the Downloads, Calculators for Metal Working category. http://www.hobby-machinist.com/resources/socket-taper-calculation-by-two-ball-method.3098/
John, I plugged the numbers from my SolidWorks drawing into your formula and it comes out with an angle of 5.4502º. I also checked the Excel spreadsheet against the SolidWorks drawing and the angles agree to eight decimal places so I'm quite sure that my equations are correct. (On the original drawing, the dimensions for d1, d2, and h were rounded off which I corrected in the drawing in the spreadsheet.)
I would be curious to see how you arrived at your equation.
RJ,
I was going through your equations, and they do work similar to mine but approach the solution in a different way. The height "h" is measured differently, so the same numbers can't just be plugged in both equations. You are measuring h as the difference between the two horizontal plains where the ball touches the taper. John and my equation measures h as the difference between the center of the two balls.
I will draw a picture or do a video when I get home tonight that shows the derivation of my equation. In addition I will show a comparison to your equations and my equation.
Thanks,
Chris
