- Mar 21, 2018
- 1,597
The "3 pieces of equal size" requirement is to prevent dishing of your plates (or, one concave and one convex). A "dished" set will look good, because all areas are ground, but in reality are unusable. Grind Plate A and Plate B in a circular pattern for 100-200 circles, then grind Plate A and Plate C in the same pattern, then grind Plate B and Plate C the same way. Since you probably don't have a Repeat-O-Meter, so grind your surfaces until the scratches are all over the plates. Proceed to the next finer grit and repeat the same grinding. At the end, you'll have three usable "surface plate lite" that can have quite good flatness specs.
McMaster has the grinding powder (use silicon carbide or diamond powder).
