When I was looking them up I saw the arbour press on some. Would be a solid spot to mount one. I have a Chinese 3 ton one, crude, but gets used a lot more than the Manley will. Most times you don't need a ton of force (pun intended) to locate or dislocate a bearing, or press in a dowel pin.
Some of them show a beam with centers mounted on the front press beam. Mine has the holes where it would go. Guessing it s for straightening shafts. Wonder if thats just the stored position, and you move it between the beams and bolt it back on to be under the ram?
Greg
Greg
