- Dec 18, 2019
- 6,483
Those little vices are handy. My most common use is clamped in the main vice to cut angles.Chose to do this using my tool makers vise.
I just recently painted the back splash on my lathe. I try to clean up after I use it. I have a vacuum cleaner underneath the lathe stand, so it makes it easy to keep things under control. I had put in a DRO and needed to slightly offset the back splash, so after that rework it was a good time to give it a fresh coat of paint.Those little vices are handy. My most common use is clamped in the main vice to cut angles.
Your lathe looks so clean. How do you keep it that way?
