- Nov 7, 2019
- 436
Quite the deja vu on that design!
So, this is probably the sketchiest way I've EVER run any kind of machine.
X and Y via g-code and Z via my powerdrill(Had to use both hands when raising due to the torque)
But now both plates are finished.
This is the outermost plate and has threaded holes in the middle and along the outer edge for vices, fixtures, whatever I want to attach temporarily.
I've also made some progress on the frame.
Nothing is glued yet because I've done the mistake before, gluing too early.
I'm fixing everything together with screws and reinforcing with dowels which should also help locate it when I start gluing it together.
I find it really difficult to get both lap joints perfect and also the overall height, so I left everything a bit long and then used the laser to cut it level.
With it leveled off, I just laid the top on to get a feel for how square everything was, and it's not far off to be honest.
Good enough considering that I haven't been very careful building this.
The top is just sitting on top right now so I made up some special dowel markers so I can use 15mm dowel rods between the standing studs and the top.
Will further reinforce everything once I have all of this glued and also the plywood sides/back/bottoms in place.
The left one is sitting in a 15.25mm hole just to be clear.
