- Mar 25, 2013
- 4,617
I realized this morning I need to get this done or Christmas would consume all my shop time.
I first rough cut it on the bandsaw and belt grinder. I mounted the bar in the mill with the vise at a 45 deg angle and cut the pocket all the way across. Then I changed out the 3/8" end mill for a drill and drilled the hole for the screw in the middle of that tool path. That way I know the distance from the back wall of the pocket is perfect.
Works great on test cuts!
Question: If my insert is a tCmt (C=7 deg relief angle) what is the minimum diameter I can turn with this? Should I get a tPmt or will the .750" bar drag first?
Robert
Robert
