- Sep 25, 2014
- 1,111
There hasn’t been much activity on this forum re the “European Style” mills. Sam has encouraged me with the pictures of his “new” FP1, so I am sharing information on my machine. I have seen them variously referred to as “Toolroom” or “Diesinking” machines. The works original documentation describes the machine as per the subject line above. For a number of years I had been milling with only a mill attachment on my 15” lathe. I had been on the lookout for some sort of a small milling machine – when, low & behold a Maho MH600 came up at the local government surplus auction.
I was faintly familiar with Deckel – never heard of Maho. A little research and it seemed like a pretty desirable machine. The next step in the story is now obvious – I brought it home. That was 3 years ago. There was nothing really wrong with the machine, but it still took me a year to get it sort of cleaned up and powered (needed a 600V transformer, which to run off my existing RPC). I’m a home machining guy, nothing happens very quickly. Anyway, the machine is from one of the local tech colleges (I actually went there myself 30+ years ago, but I don’t recall seeing this machine – that’s because it was in a back room, reserved for use by the department technician), 1963 vintage, with #40 taper and fitted with the S20x2 drawbar.
I have now used the machine a bit and love it. The main issue was cleaning and powering it. One of the comical issues I created was to wash the colour coding off the gear selector plate (fixing that became a project in itself!).
It came with a good attachment package. I was even able to get quite a bit of original documentation. Even some of the tooling came with the machine (so often at auction, the tooling gets mixed with other machines – and is never seen again. Heck, I got a bunch of Schaublin W25 collets with the MH600, wish I could trade'em for something I could use). Anyway, as with so many other individuals here, I’ve been in a continuous search for additional tooling.
Maho accessories very rarely come up. To get most of these items up front was a real prize:
I was able to track down additional collets to complete the x1/16ths set of imperial U2 collets (the long ones), and particularly the direct fit, Imperial collets #40-S20x2 (which cost me dearly). Overall, it has been a fun machine to get going. Of course, I have constantly been on the look out for more pieces to build this machine out.
About a year and a half after I got this 1963 machine, the opportunity came up to aquire the spiral milling unit – with the complete machine included (the seller would not separate anything out). I was quite concerned as it was a long way away (about 4200 km), no practical way to inspect anything, the machine had been removed from service for a while (not even a video of it running) and I had no idea how to move it. So, I bought it! Actually, it worked out okay. The seller packaged the machine pretty well and the cost to ship the machine and a pallet of attachements across Canada was $700.00 (I thought that was okay).
Now I have 2 Maho MH600s. This second machine is a 1965 machine and almost identical to the 1963 machine. I have not played with this 1965 machine, it was reported to be operable and I have no reason to believe otherwise (everything seems to be in place and there are no visual issues). Basically, it is just very dirty. I do not currently need a second machine just like the first one, and there are so many other projects I am working on.
Maho ’65 had the fixed solid table and I have cleaned it up and moved it to th Maho ’63. The benefit of the fixed table is a little more head room and a table I am able to lift myself (the universal table is more weight than I am comfortable handling safely without the little shop crane). I have a couple of little swivel vise arrangements for small jobs and that has got me by without having to pull out the universal table.
Fitting the spiral milling attachemnt will be yet another project (I actually have a project where I need this capability). I am pretty sure it is the correct one for the MH600, but the x-axis end bracket has not been drilled for the “bearing arm” – seems to have been used on some other Maho MH machine of vintage mid 1960s (the spiral milling unit was common to several sizes of MH machines). The first part of the project will be making up additional change gears (only the 5 gears that were mounted came with the machine – the other 26 gears are ??? gone).
However, right now I’m fitting a DRO to Maho ’63. The fun never stops J.
Of course I’d still like to find:
Looking forward to seeing more pictures from Sam when he gets his "new" machine home.
Regards
- The works cabinet containing
- Vertical, horizontal and slotter heads
- Universal table, rotary table, dividing head with tailstock and alternate mounting plate
- Large Pratt Burnerd Hi/Lo vise, an unusual (to me) Simco Tri-vise universal tilt swivel vise
- Punch milling attachment (still looking for an excuse to use this)
- Plus some arbors, drill chucks and collets.
- The highspeed head
- more collets (i.e. Imperial U@ collets x 1/32[SUP]nd[/SUP])
- #40-S20x2 tooling
- radius gauge for the punch milling attachement (maybe even find a project to use the PM attachment for!)
Regards
