- Aug 3, 2013
- 15
I have some brass sheet stock (about .030 inch thick) that I'm cutting little parts (about 1/4 X 1/4 inch) out of, about a 100-200 pieces in one go using a cnc mill with a little 1mm endmill. I'm using double sided tape to hold the parts and trying to avoid having to leave tabs on them to hold them down as I really don't want to finish all those tabs off by hand. Problem is the sticky double sided tape tends to come loose, parts shift and get messed up.
I'm a neophyte to machining so I'm just scratching my head trying to figure a way to hold all these sheets and was reading about magnetic chucks- I know that it's not going to hold a sheet of brass down, but maybe can you put a magnetic top layer over the brass that can get machined through, that will provide enough force to hold those little parts down? Never having actually used or seen a magnetic chuck I don't know if its far off base. Wondering if there's something that would be easy to machine through, maybe sheet metal or that kind of plastic refrigerator magnet material. Don't have any idea of the holding force that could be generated, but guessing there's not too much force needed considering the size of the cut & endmill, and the fact that double sided carpet tape is almost doing the job...
