- Jun 26, 2014
- 619
I have an old 8" x 24", 110Vdc magnetic chuck I picked up cheap at an auction site. Just the chuck as it didn't come with a controller. It is really a bit big for me - weighs about 130lbs - so it just got stuck away in a corner.
I finally got around to having a play with it last night and rigged up a variable dc supply and powered it up and it appears to work OK - ramped the voltage up to 110Vdc and the current was in line with the name plate and it held a work piece nice and solid.
Now if I'm actually going to use this I want to build a proper power supply/controller with a de-mag function (with the setup last night the work piece stayed stuck for about 20 second after the power was turned off), suitable snubber circuits to minimise any voltage spikes during switching, maybe variable hold power, etc.
So, does anyone have a suitable circuit diagram for such a controller? I am an electrical engineer by training so could develop something that worked from scratch (although it's been a long time since I did any circuit design), but there is no need to reinvent the wheel if someone else already has a tried and proven design that works.
The new controllers available on ebay seem a little expensive as I only have the equivalent of US$50 invested in this so far so spending another $300 plus on a controller isn't going to happen - if necessary I would live with the setup I rigged up last night for the minimal time I would probably use the chuck.
Edit: Chuck is a Walker Pilana model 210 manufactured in the Czech Republic
110Vdc, 1.3A, 144W, 200mm x 600mm, 60kg
