    Dismiss Notice
Magnetic chip remover/wand
Discussion in 'TOOL JUNKIES - TOOLS & TOOLING (Love Tools? This Is Your Forum)' started by ddmunroe, Jun 11, 2014.
  1. ddmunroe
    ddmunroe Active User Active Member
    1
    16
    City:
    Perth
    -Return to Top-
  2. Don B
    Don B Canada Active User Active Member
    10
    18
    City:
    Brookdale
    State:
    Nova Scotia
    -Return to Top-
    I'm not sure what thats worth but consider a cheap magnetic base, I have a base that would hardly hold it's own weight let alone trust mounting a dial to it, but it does work well for picking up chips.:))
  3. GK1918
    GK1918 United States Active User Active Member
    107
    63
    City:
    No. Dighton
    State:
    Massachusetts
    -Return to Top-
    Yes save those ole auto speaker magnets!!
  4. JeepsAndGuns
    JeepsAndGuns Active User Active Member
    14
    18
    City:
    cullman
    State:
    Alabama
    -Return to Top-
    I use a small 2.5 gallon shop vac. Works great and will even suck the chips out of the small nooks and crannies.
  5. X-RAY
    X-RAY United States Active User Active Member
    8
    18
    City:
    armstrong county
    State:
    Pennsylvania
    -Return to Top-
    funny to see this post, as i just finished making one last week. saw how to do it on the net, forgot the site though. it does fairly well, even with wet, oily chips. made from scraps i had laying around. thought i saw commercial ones for $40 or so. ill try to find the place i copied it from.
  6. chips&more
    chips&more United States Active User Active Member
    1,251
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    When you go and wave that magnet around your lathe/machine. I would be concerned about magnetizing parts of your lathe with it. And if you then magnetized your lathe, you are going to have steel chips sticking to it, making it even harder to clean! In my opinion, a bad idea. I’ll play it safe and use a brush and or vac. Besides, not everything I machine is magnetic and would not be picked up with a magnet anyway. I do not use shop air on my machines either.
  7. ddmunroe
    1
    16
    City:
    Perth
    -Return to Top-
    There is a knack to using it you don't contact machine parts just pick up chips...each time you rotate it with chips attached you lessen your chance of machine contact. Yes it does happen but in years no machine parts have become "magnetised"
    Non magnetic machining would account for 1/2 % of all machining in a typical HB shop so I would vacuum in that case as previous poster mentioned. Which is a good idea. In my training we were not allowed to use compressed air, if you were caught you would be in some trouble !
    Where it really comes in handy is when the chips are long and stringey and on the floor in hard access areas, put some gloves on and comb over the areas netting a quick catch. As you know sweeping those suckers they only get stuck in the sweeper / broom.
  8. ddmunroe
    1
    16
    City:
    Perth
    -Return to Top-
    In reading the other thread where posters have made their own, I'm going to make a narrow version for the mills t slots.
    I've been using neodium magnets for another application and think they would work well. Very strong for their size.
    I buy them from Frenegy Magnets
    http://www.frenergy.com.au/
    dd
  9. Fabrickator
    Fabrickator United States Active User Active Member
    342
    63
    City:
    Lakewood
    State:
    California
    -Return to Top-
    I use a shop vac for the most part cleaning off the mill and around the lathe. For reaching into corners of the floor and around the drill press, I use one of the Enco "Easy Grip" mag release pick up things and they work great. Floor to trash can - no mess.
    http://www.use-enco.com/CGI/INPDFF?PMPAGE=748&PMCTLG=00
    If only someone could figure out how to make an aluminum magnet, they'd be rich!
    :rubbinghands:
    killswitch505 likes this.
  10. LEEQ
    LEEQ United States Active User Active Member
    22
    38
    City:
    cameron
    State:
    Missouri
    -Return to Top-
    I would also like one made to remove the cholesterol from my beloved diner breakfast:))
  11. Componenx
    Componenx United States Swarf Registered Member
    1
    3
    City:
    Sunnyvale
    State:
    California
    -Return to Top-
    I made a similar wand about 6 months ago using a thin wall aluminum tube and end cap, some PVC, a very strong neodymium magnet, and a 2" plexiglass round as a barrier. Works great, but not for t-slots. I mainly use it to get rid of the big piles that the shop vac can't handle.
  12. savarin
    savarin Active User H-M Supporter-Premium
    1,863
    113
    City:
    Townsville
    -Return to Top-
  13. killswitch505
    killswitch505 United States H-M Supporter - Premium Content H-M Supporter-Premium
    80
    28
    City:
    Hobbs
    State:
    New Mexico
    -Return to Top-
    Man I need one for stainless lol
    Ken from ontario likes this.
Share This Page
