Machining a planetary gear set
Pevehouse
H-M Supporter - Gold Member
Oct 27, 2023
420
Hello all, I have a little project I need some advice on. Building a 4L80E transmission and doing some modifications. The plan is to put a Torrington bearing where a plastic thrust washer used to be. I would love some input on tooling and setup. Should I use carbide or hss? 3 jaw or 4 jaw. I’m new to machining so any tips you can give are welcome. Here are a few pictures of the carrier assemble and the bearing. The specs are going to be .075 deep and .370 wide if that helps. Thanks in advance
Imo this is a job that needs to be ground.
ETA: the .070 deep is how much more Clarence needed for the thicker Torrington or the total depth?
Either way it needs to be perfectly parallel to whatever the basket rides in/on.
It’s gonna all be in the setup and tooling. Triple double check alignment. Boring head and I would start with carbide you might get away with hss depending on hardness.
Yes sir, .070 is my depth. I wish I could say I have access to a surface grinder but I can’t. The carrier is actually pretty soft. The rivets are where the trouble lies. I will need to get into those just slightly
That’s kind of what I was thinking. The rivets are gonna pose the biggest challenge. Will need to just barely hit those to clear the bearing. The carrier itself is actually pretty soft. I do appreciate the expertise. Thanks
