- Nov 25, 2015
- 8,323
Machine Shop Liquidation & Estate Auction - tools - by dealer - sale - craigslist
Machine Shop Liquidation & Estate Auction – Warrington, PA Due to the untimely passing of the owner, all assets of DW Machine Inc. will be sold at absolute auction. Everything will be sold to...
philadelphia.craigslist.org
Due to the untimely passing of the owner, all assets of DW Machine Inc. will be sold at absolute auction. Everything will be sold to the highest bidder regardless of price!
View the Auction and register to bid on our NEW ONLINE BIDDING PLATFORM: geyerauctions.bidwrangler.com
Preview and Inspections: Friday March 22nd 11am-4pm
Online bidding closes Monday March 25th at 3:00pm
Machinery: Hardinge DV-59 Second Op. Lathe, Sunnen Hone, Southbend Lathe, 18" x 5
Engine Lathe, Milliport CNC Vertical Mill, Lagun Vertical Mill, Brown & Sharpe Surface Grinder, Enco Horiz. Band Saw, Dake Arbor Press, Table Saw, Welder, Miter Saws
Tooling, Test Equipment & Support: Budgit Elec.Chain Hoists, Hardness Testers & Test Blocks, Steel Shelving, Slide, Dial & Digital Calipers, Angle Block Sets & Gauges, Plug, Pin & Block Gauges, Broaches & Keyways, Micrometers, Dial Gauges & Stands, Height Gauges, Bore Gauges, Snap Gauges, Reamers, End Mills, Countersinks, Boring Heads & Bars, Radius & Telescopic Gauges, Parallels, Sine Bar, Knurling Tool Holders & Wheels, Servo Feeds, Vacuum Pumps, Go No-Go Gauges, Drills, Mills, Collets, Bushings, Sleeves, Draw Bars, Bridgeport Right Ang. Attachment, Chucks & Jaws, Steady Rests, Precision, Milling & Bench Vises, Honing Stones, Mandrels & Supplies, Geometric Die Heads & Chasers, Tapping Heads, Angle Plates, V-Blocks, Machinist & C-Clamps, Grinding Wheels, Pipe Threaders, Round & Bar Stock, Air Compressor, Hyd. Engine Hoist, Hand Trucks, Die Lift Cart, Collet Indexers, Tool Posts & Holders, Tool Steel & Inserts, Centers, Drill Chucks, Parts Sorters, Tool Boxes, Hand Tools, Steel & Granite Surface Plates, Tap & Dies, Hold Down Hardware, Punches, Countersinks & More!!
Misc: Automotive & Bicycle Parts, Flower Pots, Propane Tanks, Yard Tools, Bicycles, Car Ramps, Floor Jack, Engine Blocks,
Pickup and Removal: Tuesday March 26th and Wednesday March 27th 10am-5pm
Geyer Auction Companies
AY-000243-L
484-239-3273
