    Dismiss Notice
Machine restorers
Discussion in '++ MACHINE RESTORATION & SCRAPING KNOWLEDGE BASE ++' started by Hukshawn, Sep 13, 2017.
  1. Hukshawn
    Hukshawn Canada H-M Supporter - Premium Content H-M Supporter-Premium
    365
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    The guys on this site that restore machines, where do you guys go to get the name plates and tables reprinted on metal plates? A few of you seen several times pictures of the gear tables on my lathe and they're really quite faded. I really love to have them reprinted but I don't have any idea where to go
  2. eeler1
    eeler1 United States Dang, buggered that up too!! H-M Supporter-Premium
    149
    43
    West Sacramento
    City:
    West Sacramento
    State:
    California
    -Return to Top-
    You can restore yourself if there is enough meat left on the lettering. Keith Rucker did a video on restoring his for the LeBlond or Monarch he was working on. Otherwise, you have to get together with others that have that same machine, and hope someone has figured it out. Seems like somebody did some SB or Logan replica plates a while back.
  3. Hukshawn
    365
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    I'll win the lottery before I find original or remade parts for this lathe.
    gregc likes this.
  4. Hukshawn
    365
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    I'll check that video out.
  5. Hukshawn
    365
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    Keith was restoring a stamped plate, mine is printed. I cannot use his same method. But thanks for the reference.
  6. dlane
    dlane Active User H-M Supporter-Premium
    790
    113
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
    What u got, there could be repops out there
  7. Hukshawn
    365
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    There won't be spare plates out there. I literally cannot even find another one of these lathes never mind parts.
    There is a company H.R Roberts machinery that has the blueprints to make parts but they are astronomically expensive. But I have emailed them already. I've also contacted a local trophy shop that had printed on brass plates for me when I made my brother in-laws urns a few years ago.
    We'll see what I come up with. I was just putting feelers out there what some of the guys here have done.
  8. dlane
    790
    113
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
  9. Cadillac STS
    Cadillac STS United States Active User H-M Supporter-Premium
    136
    43
    City:
    Grand Rapids
    State:
    Michigan
    -Return to Top-
    I would call a local silk screening place. They would have access to someone to draw the art from your current plate (To make the screens) in each color you want and could silk screen it on a metal plate for you. In High School 30 years ago we had a setup for that, very easy to do.
    If just one color I saw a process somewhere where you print on a special paper on a laser printer then iron on the lettering from there to the metal plate so you could do it yourself if you could draw up the images and had access to a laser printer. Someone was doing that for making pc boards on copper clad boards. Then cover with clear lacquer to protect it.
    The good thing about the rare lathe is you can make the plate like you want it so long as it looks good no one would notice because no other machine to compare to. No pressure on getting exact match, just a good clean plate.
    4gsr and Hukshawn like this.
  10. RandyM
    RandyM United States Global Moderator Staff Member H-M Supporter-Premium
    1,042
    113
    City:
    Stoughton
    State:
    Wisconsin
    -Return to Top-
    I use a local graphics or sign company. They have a lot of tools to make new. One company is an engraver and I will have some stamped plates engraved. I have found that they are very reasonable for their rates. I have a challenge coming up, a Logan stamped name plate. It will be interesting as to what I find out on this one and the compromises I may have to make.
  11. rowbare
    rowbare Canada Active User H-M Supporter-Premium
    18
    18
    City:
    Ottawa
    State:
    Ontario
    -Return to Top-
    John Saunders posted a video showing one technique to make a filled brass plate:
    If making steel plates, you can use printed circuit board techniques. Reverse laser print on a transparent material and iron it onto the plate. Put some resist coating on the back side and dip in some ferric chloride solution till you get to the desired depth of etch. You can get ferric chloride from most electronic component stores.
    For a printed plate, I have thought of printing on a t-shirt transfer sheet and applying that to the plate. I have yet to try it so I can't confirm whether this will work or not. You would need to apply a clear protective coat afterwards.
    You can also get laser and inkjet printable decal sheets. Same as above, have the material but haven't tested it.
    Of course all of these depend on having a cleaned up graphic of the original plate.
    bob
  12. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    961
    93
    City:
    Worcester
    State:
    Massachusetts
    -Return to Top-
    I've used decal printer paper for machine logos. It seems that you could use it for metal data plates as well.
  13. Hukshawn
    365
    63
    City:
    Bowmanville
    State:
    Ontario
    -Return to Top-
    All of these printer methods are okay with the oils and solvents? We have a laser printer... I wouldn't know what paper to use tho...
    All of the companies I called cannot do what I'm asking.
  14. kvt
    kvt Active User Active Member
    661
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    I am also interested in the laser printer paper one, As I have an Asian lathe that needs tome new labels Single color will work. But right now I have nothing.
  15. Cadillac STS
    136
    43
    City:
    Grand Rapids
    State:
    Michigan
    -Return to Top-
  16. Superburban
    Superburban United States Active Member Active Member
    196
    43
    City:
    Grand Junction
    State:
    Colorado
    -Return to Top-
    I read that Testers makes a printable transfer decal paper. Like the iron on stuff, but works with water like the decals that come with the plastic models. The article said it works great for logos and info plates.
    Here, I found it.
    http://wiki.vintagemachinery.org/CreatingDecals.ashx
    brino likes this.
  17. MozamPete
    MozamPete South Africa Active User H-M Supporter-Premium
    719
    93
    City:
    Ladysmith
    State:
    Outside US / Canada
    -Return to Top-
    I have used the laser printer decal paper for some labels. I brought the clear background (you can also get a white background decal paper) to allow the machine colour to be the background.
    The results were varying. The laser printed colour is not so vivid so can appear a bit washed out and hard to see on a dark background, but works quite well on a light background.
    brino and francist like this.
Share This Page
