- Feb 25, 2021
- 3,130
I’ve let myself get dragged into a few discussions on VFDs, and I see a bit of confusion on why inverter rated motors matter.
To start with, motors all generate some amount of heat. That heat is wasted energy, electricity that could have been turned into motion, but instead just generated heat. If you get nothing else out of this, just remember heat is wasted energy as far as motors are concerned. (If you’re trying to heat you room, that’s another story). Heat is also what eventually kills motors. Bearings wear faster when hot. Lubricants break down faster. Insulation fails faster. Copper wire corrodes faster. Most of these aren’t instantly catastrophic if not taken too far. Like running your car hard, or pulling a heavy trailer, your car’s life will suffer, but unless you get wild, it won’t die immediately. How badly a motor will suffer is almost like predicting how long your car will last. Manufacture, make, model, road conditions, and luck of the draw all play some part in that.
Of course temperature is the actual killer above. Sure, more heat increases the temperature, but fans, and lower ambient temperature will reduce the temperature rise. Motors are designed to not overheat by adding enough fan air movement to keep them within reasonable temperature. Just like a car’s radiator. But if the motor is operated outside it’s designed parameters it risks overheating.
Since we’re often using general purpose motors in weird ways, we have to have some understanding of what causes overheating to make a good guess at whether our motor will work well for a given application. Of course, if you’re in the business of using motors to make high efficiency systems like HVAC systems, you also want to get the most motion for your dollar of electricity. The cost of the motor may be significantly less than the lifetime power costs. ( This was the real motivation for early VFDs, saving electricity). As home, or even professional machinists, electrical costs are rarely a big factor in how we use or set up our equipment.
Many motors actually give you an efficiency rating. That rating is at optimum conditions, sort of like MPG in your car. Usually its at 60Hz, and about 75% of rated power. Generally anything else is going to be less efficient for that motor. But it is not easy to determine how much less efficient. Efficiency is simply the power creating motion divided by the total power used. Heat is pretty close to total power used minus power of motion. (air movement from the fan and noise created also use a small amount of power.). What this means is if the motor is generating less power of motion, than for the same efficiency it is generating less heat. Or,
heat = (1-efficiency) * actual horsepower output. Unfortunately efficiency does change a bit with horsepower output, but not drastically, so you can get dome idea from this of whats going. And it’s pretty intuitive, that motor is going to get hotter if it’s cranking out more power.
With all that said, here are some things that waste energy in a motor:
The fan cooling the motor.
Friction in the bearing.
Resistance of all that long thin wire.
Eddy currents in the material of the electromagnets
Magnetic hysteresis and saturation
Air gap between stator and rotor
Yikes, what a list! I’m sure I’ve missed a few too.
The first two are actually fairly trivial. But the fan plays an important role in getting rid of heat. Fans are noisy so generally an oversized fan is avoided for that reason. And increasing airflow also means a bigger motor. If a motor is always going to run at good efficiency we can optimize that fan and airflow. And of course fan speed matters if we start using a VFD. Bearing friction depends on rpm and load on the bearings. But they are pretty good, which is why we use them.
One way we can shortcut all of this loss stuff is just make some measurement.
Power in is easy to measure electrically. P = Volts * Current. But that only works for DC.
For three phase, P = Volts * current * sqrt(3), if the current and power are in phase. If not in phase, which means the sine waves are shifted left/right of each other, then
P=V*I*sqrt(3)*cos(c). C is the amount of shift between them, and is usually written as the greek letter phi. I just don’t know how to get that greek letter while typing this on my ipad . Phi is also related to what is called power factor.
Usually we know our voltage. 230V, 120V, etc. We match our motor voltage and our utility voltage, hopefully.
An ammeter will measure current. But that damn phi gets in the way. You need an oscilloscope or other fancy equipment to measure that. One way this shows up: most AC motors run a fairly high idle current. You can measure it with a clamp ammeter. Often 30 - 40% of full load current, which is called FLA (full load amps) in some motors and VFDs. So we’re using 1/3 of the electricity and getting zero useful motion? Well yes. But the motor at idle is basically borrowing that current and then sending it back to the power company with every 1/2 cycle of your 60Hz. It is acting mostly as a straight inductor, which doesn’t use real power. It uses reactive power, or as the engineers sometimes call it, imaginary power. That current still generates loss in the power distribution system though, so the power company isn’t keen on that borrowed power. Industrial customers generally pay a fee for that, homeowners typically get away “interest free” on that very short term borrowing. As the motor goes from just spinning with no load, the current will increase, AND the phase angle will reduce. As that angle gets less, cos(c) gets closer to 1. Borrowing less power and actually using it to generate useful motion.
Ok, enough for one night of single finger ipad typing. I will take a crack at more tomorrow.
