- Oct 16, 2019
- 6,579
Thanks, none of those look to be locking casters. It doesn’t move around when in use?
+1 ! There are some great blogs on the similar machines like Rick Sparber's site. It's very cool yours has the metal guards over the Y lead screw. With mine there was a rubber sheet on the back side between the mast base and the table base and the previous owner didn't think he had to replace it when it died There was a TON of swarf in there as 75% of everything goes back there. i hope your table has a hole in the bottom to be able adjust the Y split nut. Pulling and cleaning and lubing the lead screws and nuts along with the table ways made a huge difference in my RF30.Don't take it too far apart, sometimes those rabbit holes go lots deeper than you want to go. Start with some cleanup & inspection, maybe some paint & lube & see how she works!
Yup, I knew it looked hard just looking at the weight and the fact that unlike a knee mill you can't just loosen some adjusters and get 'er done. But when you start contemplating the distances involved and how microscopic changes in the base are magnified.......scary. I'm totally a deer in the headlights with the thought of that wabbit hole. Have you checked Stephan Gottswinter's YT on his tackling of this subject on his RF 45 clone? That's in one way the best way possible and the most detailed and daunting way to tackle it. Usual Stephan G. The guy blows my mind. That's not a wabbit hole, it's more like a crater!Thanks @C-Bag I will say that Rick's treatises on tramming are a bit daunting. It sounds as though tramming a mill/drill is many times more difficult than a regular mill. So more distance between the column base and the spindle centre magnifies the fore and aft tram?
I'm trying to wrap my head around this as dig in.
