Hmmmm....
I'm not seeing what you are referring to here in terms of its usefulness? I assume you mean while synchronizing the shifter? I did mine only a couple of weeks ago, and my feeble brain has already dumped what I learned then. I don't want to miss out on any neat tricks! As I recall, once I had the teeth meshed, and was happy with the lash, I simply locked the collar with about 1/16" free gap from when the latch key popped into lock position.
I had to go back down to the basement last night and refresh said feeble brain on how it all worked before I posted at all. As I had recalled, the only issue for me in getting back gears engaged is whether the gear teeth are meshing. If they are it slips right in. If not, a little turn of the spindle finds a mesh point quickly. I suppose it bears mentioning that you never want to do ANYTHING with the back gears while the lathe is running. Given the sorry state my lathe was in (mine HAD no shifter, etc), I wonder how many times someone shifted it on the fly?
Then again, that is probably an obvious answer.... ONCE!
